درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام actionAddReply seems to return error prematurely? ایجاد شده است. این موضوع تا کنون 164 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع actionAddReply seems to return error prematurely?
I've got some code in my addon that extends Pub/Controller/Forum and intercepts the reply from actionPostThread to change a certain error reply (which I create in setupThreadCreate) into a view where the error can be corrected by the user. That all works fine.
I'm trying to do the same thing in the Pub/Controller/Thread to intercept the reply (created in setupThreadReply) in a similar way and I can't see why this isn't working. If I put the following in as my...
XFFA.IR Bot Weird user agent that seems to want money? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Color picker (alpha) seems broken when variations are disabled فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Search from a members profile seems to be broken فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Structured data: DiscussionForumPosting property dateModified seems wrong فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is xenForo.com on 2.3? Seems *much* faster today! فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot \XF\Util\Random::getRandomString() seems suspectible to timing attacks فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot vBulletin 3.8.x importer seems to be stuck in loop on posts step فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot vBulletin 5 Authentication handler seems to be completely broken فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Turnstile integration seems (partly) broken فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot It seems XenForo doesn't have a 'joinable groups' feature. Is this ever going to be built-in in the future? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I thought site was hacked - but seems to have been Google فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I need help reverting my forums from Adsense to Google Ad Manager which seems much more complicated - anybody else done this? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Originally posted in: <a href="{link}">{title}</a> seems to be duplicated فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Push Notification Notice seems to be persistent فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hosting company upgraded tp PHP 7.4.12 and that seems to have broken xf 1.5.21 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Today's xkcd seems to belong here فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Stripe seems to be charging 1 penny less than the actual amount for subscription. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot (Solved) Seems XF2.2 has changed something regarding retrieving values of custom thread fields? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Seems XF2.2 has changed something regarding retrieving values of custom thread fields? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Content bookmarks and the return of per-post share controls فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Return of banned users - how reliable is a v6 IP-address as a criteria? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Wrong return type hint on XF\Search\Query\MetadataConstraint::getMatchType فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot AbstractCollection->pluck() should always return collection when $collectionOnEmpty=true فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Search of commands doesn't return anything فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Method em()->create return hint incorrectly فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Too wide Finder return types from repository functions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot TypeError: XF\App::job(): Return value must be of type XF\Job\AbstractJob, null returned in src/XF/App.php at line 3223 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot calculateOptimalBatch can return values larger than maxBatch فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to manipulate payment return فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After import, forums return a 404 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot API - return media with a rating of > 3 stars فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Check box option value = '', but return `1` فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot TypeError: Return value of XF\Job\PermissionRebuild::rebuildById() فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Return messages from preSave, without stopping execution فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Conversation::assertViewableMessage: array_unique return value discarded فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Callback return on load فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleted threads should return a 410 server message instead of 404 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Restoring SHIFT+TAB functionality to return back to the message field after replying? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Testing URL unfurling does not return a useful error for a bad url فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot CategoryTree return no data فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Use of return for new paragraph فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Return HTTP 503 causes XenForo to be virtually unusable behind a loadbalancer فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot "Return to Forum" button above the quick reply window... فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Xenforo return blank screen on every page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot BB Code to return value of custom user field فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Return more “new posts” فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot $this->service('XF:Post\Editor', $post) return unexpected result فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Return more info about quoted post in API blockquote markup فیدخوان خبری از سایت xenforo.com 0
