درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Ad-position \"Post: Below message container\" is not between posts in thread type question ایجاد شده است. این موضوع تا کنون 255 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Ad-position \"Post: Below message container\" is not between posts in thread type question
Normally this position is between posts, in thread type "question" it looks if it is in first post.
Could you replace the class "block-container" for the first message with "block--messages"?
This is what it looks like in a normal thread:
this is what it looks like in a question thread right now:
This is what it would look like if the class "block-container" of the first post would be replaced with "block--messages":
XFFA.IR Bot postMadeVisible does not function correctly when undeleting a post and changing it's position فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot New post does not scroll to correct position فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [cXF] Advertising position after first post فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Editing post with smilie as last character caret position incorrect فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Minus sign position in a question type post (RTL) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Ad position above message content only show in specific user's post فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [OzzModz] Change Post Position [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [cXF] Advertising position after first post افزونه های مدیریتی 1
XFFA.IR Bot Widget position فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Date position in the date field is wrong with RTL فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Remember last position in a thread فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Ad in position forum_view_above_node_list will not show on categoryOwnPage فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Avatar position on profile page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Possible to switch widgets in the same position via a link? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XFRM Resource Manager Change Download button position, text and colors فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Show widget only in position on home (forum default) page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Navbar position change to left sidebar فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot "Insert link" doesn't respect cursor position anymore since XenForo 2.2.13 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot fastupdate position -1 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Forum list: Above nodes widget position should be above Forum List title فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Widget position using +/- فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Where to edit mobile online status indicator position? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF.pageLoadScrollFix() causes browsers to lose scroll position on reload فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add an ad position between Public: Sidebar top / bottom فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Ad position in <head> فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Quick reply anchor position? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Widget position: Resource View فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Widget Display Position for Search Results sidebar? فیدخوان خبری از سایت xenforo.com 0
King ویژه [XFI] Tag Position افزونه ها 0
XFFA.IR Bot Missing field "position" Breadcrumb markup فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to change position of p-navSticky to center? فیدخوان خبری از سایت xenforo.com 0
Dariush [cXF] Last Edited Position افزونه های مدیریتی 1
XFFA.IR Bot [cXF] Last Edited Position فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Define Order of Forum Threads by Position فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to improve your forum SEO and Average Position ranking فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Right Sidebar Ad Position Placement فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Headlines in post body do not get rendered reliably فیدخوان خبری از سایت xenforo.com 0
