درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Add-on versions for breaking XF changes ایجاد شده است. این موضوع تا کنون 123 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Add-on versions for breaking XF changes
What is the best practice for releasing add-ons that have a breaking change between XF 2.2 and 2.3?
Should I release a new add-on with the same name or should I have a single add-on and identify the version of XF and have logic specific to each version? If I should have a single add-on version and identify the board version, what's the easiest way to obtain the board version?
If I should have a single add-on but determine version specific code, should I do something like this?
PHP:
if...
XFFA.IR Bot Add compatible PHP versions field for XenForo add-ons فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to add Stripe trial periods to User Upgrades? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there a way to add a widget under quick reply? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Option to notify moderators/admins, or add the post to the mod queue when edited. Ideally it would be for all public edits, including profile content فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to add permanent usergroup to user account upgraded? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Which add-on can do this ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add option to hide or ignore other users’ profile pictures فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom Add-on Request for RSS Media Feeds فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is this normal? Add Template Modification got style selection? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to create/Add widget positions? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to add logo to the right side of the header فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is it possible to add message/like ratio on postbit? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add [hide] automatically to URL tag فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How hard is it to add a new payment provider? (that isn't one of the built in options) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot add a new family font to editor فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is it possible to add a nofollow link in "Public Navigation"? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo developer needed for fix an issue on an add-on فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Developer Needed for Add-On Conflict فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can we add our user's email addresses to their profile? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot add a word counter to the editor? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there an Arcade add on? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add a simple and effective Reputation System for your Forum فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Allow ownership of custom fields by add-ons فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add footer link to help page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add the editor to a template فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Currencies Supported for Paid Subscriptions Add-On فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Author/Original Poster Views Do Not Count Add-on Request فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Issue Installing Steam Authentication & Integration Add-on – ZIP Archive Not Recognized فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add preload to videos فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I found the man who stole other's add-on فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Where and how to add schema markup فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Two Small Add-ons Development Request فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [Andrew] Add-on Log [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Posting via Postman to api/threads brings back list of threads and not add a thread فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Plugin to add SEO content inside Forums and below posts? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Update an add-on developed by a different developer فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Navigation How do I add an icon? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Experienced Developer for Migration XF 1.5 to 2.3 & Add-on Updates/Upgrades فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot add-on for security فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do you adjust/remove the breadcrumb on AdminCP instead of the add-on? فیدخوان خبری از سایت xenforo.com 0
