Adding quotes when editing a post is very odd process
XFFA.IR Bot
امتیازها 113
راه‌حل‌ها 27
  • Select some text in a post
  • Click on +quote
  • Click on edit under one of your posts
  • No "Insert quotes available under text box of the post you are editing, but is there under the reply text box at the bottom of the page, and inserts the quote into the post you are editing. It works but very unintuitive to have to go to the insert quotes at the bottom of the page.
