درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام After Upgrading from 1.5.20 to 2.2.1 MG 2.2 loads totally slow 20sec+ ایجاد شده است. این موضوع تا کنون 194 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع After Upgrading from 1.5.20 to 2.2.1 MG 2.2 loads totally slow 20sec+
The upgrade self was seamless and it's all fine but a click on "gallery" gives everyone a "little break" of around 20 seconds.
It was extremely fast before on 1.5.x with MG 1.x as i run it on a VPS with 10cpu, 60gb ram and SSD only with 1gb network in a modern 460gb network datacenter.
Forum runs on PHP 7.4.11 FPM/nginx and nginx proxy. It's all lightning fast but the first loading of the gallery (always on click).
i experienced that even on my testing-clone before so it is reproducable...
XFFA.IR Bot After Upgrading from 1.5.20 to 2.2.1 MG 2.2 loads totally slow 20sec+ فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot 403 Forbidden - When upgrading to 2.3.6 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading from XF 1.5.24 to 2.3.5 still broken فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After upgrading XF to 2.2.16 patch2. I am prompted to upgrade MG to 2.2.6? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Help Upgrading فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Stuck on Processing on anything when upgrading to 2.3.4 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Uncaught Error: Call to undefined function mb_internal_encoding() when upgrading to 2.3.3 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Icons font awesome lost after upgrading to 2.3 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading from 2.2.16 to 2.3 Troubles فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [GUIDE] Upgrading from XenForo 2.2 to XenForo 2.3 Guide فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Forum icons disappeared upon upgrading to 2.3 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading from XenForo 1.5.5a to 2.3 doesn't work فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot a problem occurred while upgrading فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading from XenForo 2.2 to XenForo 2.3 Guide فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot upgrading to XF 2.3.0 - not available upgrade script فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Server error after upgrading to 2.3.0 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Error in the post and reply writing box after upgrading to 2.3.0 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot JS issues after upgrading to 2.3 RC1 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Site not up after upgrading to 2.3 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Issue Upgrading to 2.3.0 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Errors on upgrading to 2.3 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading When I do not have Access to the Current License فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading from XenForo 1 to 2 and XenMedio 1 to 2 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Errors when upgrading from 2.2.16-Patch-2 to 2.3 RC2 --- LogicException: xf_job: priority already exists in table, but cannot change length in src/XF فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot MariaDB failed to start after upgrading to php8.1.29 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Mysql error upgrading to 2.3 beta 4 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After upgrading, all I see is boxes now (pic included) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Manual upgrading from 2.2.13 to 2.2.15 - compileAst() error فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Server Error Upgrading To Latest Version فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading to 2.2.14 reset asset folder فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading large forum from XF1.5 to XF2 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading Xenforo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Manually Upgrading an account doesn't sem to do anything فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Installation redirects to upgrading فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading the Guzzle 7.x فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot upgrading Mariadb from 10.6.15 to 10.6.16 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading to 8.1 extension question فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading Centos 7? or waiting? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Error style when upgrading from XF 2.2.12 to 2.2.13 (continue) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Error style when upgrading from XF 2.2.12 to 2.2.13 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Error message after upgrading to XenForo 2.0.10 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading XenForo license فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Correct way of upgrading an addon? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After upgrading to 2.2 smilies are not working فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Problem upgrading forum فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After upgrading to XF 2.2.7, the default Copy+Paste behavior for images is to use [IMG] tags. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Error upgrading to XF 2.2.7 Patch 1 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading to 2.2.7 Crashed Dev Site فیدخوان خبری از سایت xenforo.com 0
