- تاریخ ثبتنام
- 2020-06-26
- نوشتهها
- 21,039
- راهحلها
- 27
- پسندها
- 3,261
- امتیازها
- 113
- سن
- 27
- محل سکونت
- England
- وب سایت
- xenforo.xyz
If I am setting up a navigation entry, I can set the link to
I would like to see similar behavior allowed in Link Forum nodes. Currently these must be hard-coded, which means that if a route filter is applied or the root domain changes (such as when cloning a prod instance to a dev instance), these Link Forums must be manually updated to point to the...
{{ link('path/to/resource') }}
and the link will automatically update to match any root domain or route filter any time the page loads.I would like to see similar behavior allowed in Link Forum nodes. Currently these must be hard-coded, which means that if a route filter is applied or the root domain changes (such as when cloning a prod instance to a dev instance), these Link Forums must be manually updated to point to the...
