درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Animated (GIF) avatars terribly supported? ایجاد شده است. این موضوع تا کنون 23 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Animated (GIF) avatars terribly supported?
I noticed the day I installed Xenforo, that Animated avatars are terribly supported on Xenforo. With GD, the gif file uploads but only a static avatar image is being shown, and with imagemagick I get constant timeout errors. Now, I could increase the timeout. But to do that for a simple 96KB GIF avatar that couldn't even be converted within 30 seconds? That's overkill.
I know there may be a lot of frames within that GIF avatar, but I have to admit with vBulletin I never had any issues...
XFFA.IR Bot How to disallow animated gif avatars فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Animated Avatar Permission [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Enabling animated avatars? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Uploading multiple GIFs as attachments - Only 1st is animated (See zip to replicate with 2 others) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Animated gifs as avatars and dealing with the CPU load from imagemagick فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Animated online indicator فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Animated avatars. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Importing animated smilies from vB فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Animated Avatar to a specific usergroup فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Prevent users from using animated images in signatures? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Animated JoyPixels in reactions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to animated username style فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot alright, animated avatars stage 2 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot گرافیک [ITD] Animated Smileys Pack I دانلود امکانات گرافیکی 0
XFFA.IR Bot [UH] GD Gif Animations فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image optimization: GIF to Webp, What are the required libraries on the server? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot what is cleardot.gif فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot GIF upload time slow/fails فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot gif to webp optimization problems فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to embed a Tenor GIF? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot GIF Attachments Larger Than 2 MB Are Refused فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot "Issue" with GIF search bar and the cursor. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot GIF Avatars فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Profile Cover as GIF فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot webp gif animation lost on upload فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Dragging a GIF into the post field leaves behind a ghost image.. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot add alt to "add_to_home.gif" in PAGE_CONTAINER فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User unable to add gif, use bold/italics, etc. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot add_to_home.gif فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot gif uploading via window key - peroid on windows 11 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do I fix embedding a gif into my forum post? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Cloudflare Mirage disables the GIF under "Install the App Button" فیدخوان خبری از سایت xenforo.com 0
AAA درخواست درخواست افزونه برای وارد کردن لینک gif در مطلب درخواست استایل ، افزونه و آموزش 5
XFFA.IR Bot [OzzModz] Gif Avatar Permissions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do I enable gif avatars? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot GIf upload problem فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I can't add gif to usertitle فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot GIF permissions?? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Unable to add GIF button to ANY editor toolbar فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [JUM] No Gif Avatar فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Issue Uploading Gif Avatars فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Insert GIF button that shows search results for Giphy فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Xenforo GIF avatars فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Mass delete all avatars? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Avatars missing after migration from phpBB فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Remove unnecessary lazy loading of avatars, emojis, and smilies فیدخوان خبری از سایت xenforo.com 0
