درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Article Threads: Reuse Chunks of Content (An Article Template System) ایجاد شده است. این موضوع تا کنون 215 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Article Threads: Reuse Chunks of Content (An Article Template System)
Have you ever created a group of articles, and found that you kept re-using the same chunk of content over and over again?
Maybe it was a list you had to include for a product or a profile you posted each time you created a new article. Each time you wrote the article you found yourself repeating yourself. Maybe it was just boilerplate language you had to include each time you made one of these posts.
If you were smart, maybe you created a document somewhere you...
XFFA.IR Bot How to change the width of article threads? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Bob's Article Management System, articles to threads? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Article threads - do not want about tab from profile in author bio فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Have an option to have Article previews for normal threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Article threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Question About Xenforo Article Style Threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Moving Discussion threads to Article forum produces error فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Exclude threads from Article forums list فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Article threads and data usage increase فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Set max width, increase font size for article threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Thread view count for article threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Extend higher limit constraints to attachments on article threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Search forum to display article type threads preview e.g. for portal فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Resource threads in forum become disconnected from Resource when the forum type is changed to Article فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot No indication of sticky Article threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot For Article threads use first article image (if one is available) as opengraph & twitter image فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there a way to remove "Thread" at the be beginning of each featured article? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Sticking an article messes up grid count فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Trying to specify different node icon for question and article nodes? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Moderation status icon is shown 3 times for article preview فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Anchor links in article not working فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Article forum list include links to unread and or last post فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Expanded Article in xfrm_overview فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot about us on horizontaal postbit of article thread types فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Prefixes in article forums (only) have bold text فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Article Permission فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XFA] Document/Manual/Tutorial/Article Writer [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Article thread - text wrap فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to default thread article posts to full view فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Same look as nodes/article/expanded view - but needed in "New Posts" widget فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot #1 post = article, can't use inline edit فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to get cover image of an article typed thread with REST API فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do you delete one page from an article? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Article layout, trending and featured content standard layout فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Target Article from Thread (which doesn't appear to be a post?) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do I make the article appear with the image and title only? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image for article and featured content فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Article Management System ("AMS") Links Auto-Updater فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Sidebar for homepage using article layout فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Paid - Summary on article thread list فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to show cover photo without it as an attachment in article 'Preview'? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Blog/Article> Forum فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Article or Discussion for different types of content and SEO? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Don't remove line breaks and formatting from article snippets فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot General Discussion or Article forum type in forum_view فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do you get to the Latest Post of an article? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to show full article images to non-registered users فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Expanded Article type view count فیدخوان خبری از سایت xenforo.com 0
