Assuming default privacy policy, any possible legal repercussions for selling a forum along with database?
درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Assuming default privacy policy, any possible legal repercussions for selling a forum along with database? ایجاد شده است. این موضوع تا کنون 175 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Assuming default privacy policy, any possible legal repercussions for selling a forum along with database?
If someone sells a forum as a going concern and all users on the database agreed to nothing other than the stock T & C and Privacy, could there be any legal issues?
I always assumed there is nothing in GDPR that implies it could be a problem and loads of forums are sold, but I imagine some users may get annoyed if a forum they were on changed hands. Do you need their consent?
XFFA.IR Bot How to get the Current Visitors page to default to the Members tab? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [Suggestion] Specify 'Custom Thread Field' default values فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Different Coloured default pages and ACP's فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot About tab default [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF Default “Forums” Reference in URLs فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot copy & paste of image to make an attachment is blocked as webp isn't an allowed extension by default فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Make full view counts the default فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Change the default user preferences timezone for new users فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to edit or change Xenforo's default "resource manager" / resources icon? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add default sort order for albums - and filter by title فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting like $config['adminColorHueShift'] for the Default style? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot threads/ API endpoint has a "last_days" default? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Default avatar to image فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Display results as threads/grouped should be the default فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [OzzModz] Forum Type Discussion: Default Thread Type فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is this an ancient default XenForo smilie? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Most points as default فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add spellcheck="true" to the editor to enable spell checking by default فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Changing default theme changes others' themes فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Style Variation Default فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [Patch Included] Style variation chooser icons don't support non-default weight فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Tagify Questions: Force Dropdown Selection & Default Values فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Search: Changing default from Everywhere to forum/category فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Default image for trending threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to default thread article posts to full view فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to re-order thread type selection (default to Questions)? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Media description expanded by default? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to change default icons? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can't prevent default submit behavior via JS فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Why no default icons showing in my forums? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to keep open the Categories Menu by default ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Enabling email notifications by default فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to remove default icons in xf 2.3 فیدخوان خبری از سایت xenforo.com 0
