درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Correct way of upgrading an addon? ایجاد شده است. این موضوع تا کنون 86 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Correct way of upgrading an addon?
So I used the release command on version 1000030 to prepare the zip file and uploaded it to the remote server and installed the addon.
Now if I want to work on additional things related to the said addon locally, what would be the recommended way of dealing with upgrades?
Approach #1
  1. Bump the version to 1000130
  2. Start making changes to code/templates
  3. Once I'm done with the changes, use the release command to get the zip of the upgrade...
XFFA.IR Bot API: How do I properly create versions with correct release date? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Correct Paypal IPN Settings in 2.2x فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Spacing is not correct فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot New post does not scroll to correct position فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Am I making this ajax request correct? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Xenforo 2.2 -- Some forums are not showing correct thread counts (e.g. 0 when there's 10) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Uploaded file size is too large - All settings correct فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot give correct error message instead of "oops" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot PhotoPost Pro Importer: Member albums not imported into correct category فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Reaction title doesn't use correct language in push notifications فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Correct Way Of Doing User Group Permissions? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Quoting post results in wrong user/postlink but correct message فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Correct reaction titles not appearing فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Correct file ownerships throughout installation فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot 403 Forbidden - When upgrading to 2.3.6 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading from XF 1.5.24 to 2.3.5 still broken فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After upgrading XF to 2.2.16 patch2. I am prompted to upgrade MG to 2.2.6? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Help Upgrading فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Stuck on Processing on anything when upgrading to 2.3.4 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Uncaught Error: Call to undefined function mb_internal_encoding() when upgrading to 2.3.3 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Icons font awesome lost after upgrading to 2.3 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading from 2.2.16 to 2.3 Troubles فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [GUIDE] Upgrading from XenForo 2.2 to XenForo 2.3 Guide فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Forum icons disappeared upon upgrading to 2.3 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading from XenForo 1.5.5a to 2.3 doesn't work فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot a problem occurred while upgrading فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading from XenForo 2.2 to XenForo 2.3 Guide فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot upgrading to XF 2.3.0 - not available upgrade script فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Server error after upgrading to 2.3.0 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Error in the post and reply writing box after upgrading to 2.3.0 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot JS issues after upgrading to 2.3 RC1 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Site not up after upgrading to 2.3 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Issue Upgrading to 2.3.0 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Errors on upgrading to 2.3 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading When I do not have Access to the Current License فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading from XenForo 1 to 2 and XenMedio 1 to 2 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Errors when upgrading from 2.2.16-Patch-2 to 2.3 RC2 --- LogicException: xf_job: priority already exists in table, but cannot change length in src/XF فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot MariaDB failed to start after upgrading to php8.1.29 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Mysql error upgrading to 2.3 beta 4 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After upgrading, all I see is boxes now (pic included) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Manual upgrading from 2.2.13 to 2.2.15 - compileAst() error فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Server Error Upgrading To Latest Version فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading to 2.2.14 reset asset folder فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading large forum from XF1.5 to XF2 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading Xenforo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Manually Upgrading an account doesn't sem to do anything فیدخوان خبری از سایت xenforo.com 0
