درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Custom field management\/coding ایجاد شده است. این موضوع تا کنون 37 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Custom field management\/coding
We have a couple of different XenForo forums that include custom fields to gather the users' first and last names. It is then displayed in the user message box, in the posts Message_User area and also within their profile. We chose to separate the two names as they are a requirement to register and having a single field for name, we found we were often not getting the full name. Now, the issue
With the two names, is there a way to combine the two into one for posting on the forums? I know...
XFFA.IR Bot Output display of custom field (multiple-choice drop down) as list view? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom Field Improvements: Searching! فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot ErrorException: [E_WARNING] Array to string conversion if custom field has unexpected value فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom Field Improvements: Filtering and more! فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XB] Custom Field View List Display [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom user field linked to user group فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [BraisDev] Custom User Field API [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Move custom field order فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User must select Custom Field فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XB] Custom Field Change Log [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [Suggestion] Specify 'Custom Thread Field' default values فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can a Custom Thread Field be formatted to display as a Media BB Code? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom user field-how to adjust it to get it to where I would like it to be? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Search for custom user field فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Tagging users via custom user field فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add link to custom field in message user info فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to display an image in a XenForo Custom Field? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Merging threads removes custom field data فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Getting Custom User Field Text فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Member Custom User Field Search فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XB] Custom Field Hidden Display Location [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom Profile Field Categories فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [vbresults.com] Custom Field Regex Capture فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to Handle Custom Thread Field error ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Looking for a way to sync secondary group memberships to a custom field فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom field for file uploads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XB] Custom Field: Select All [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Show custom thread field only to guests فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to show a custom thread field number value with commas ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to create a custom thread field with latest 5 years (auto-update upon new year) for users to choose from? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Ability to Consolidate options in Custom User field choices فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Consolidating custom user field choice options فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom Field Dependent on anothers Custom Field Input فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Optional custom user field on registration فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom Field - Upload file فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom User Field On Registration فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom Field Permissions & Edit History فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom Thread Field error فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Bluesky custom field & username validator فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Convert a text box to drop down custom field فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Improve date() or <xf:date> for templates or store custom field dates as unix timestamps to the day only فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom User Field in User Banner section? فیدخوان خبری از سایت xenforo.com 0
