درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Disallowing re-using of existing password when changing passwords. ایجاد شده است. این موضوع تا کنون 99 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Disallowing re-using of existing password when changing passwords.
I have the dragonbyte security add-on that has the option to require users to change their passwords after a certain time period.
Some users on my forums remarked that they were able to re-use their existing passwords again, when they "change" their passwords.
This basically means they can use the same password perpetually, which kind of defeats the purpose of forcing a password change. :p
Is this an intended feature of XF?
should I take up the issue to dragonbyte instead?
XFFA.IR Bot Revise all the developer docs (and maybe even the normal docs) using AI فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Using chatgpt to create addons for Xenforo? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot xf_search growing to 5 GB+ even when using elastisearch/enhanced search فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Email Confirmations not sent to users, including myself using gmail فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is anyone using Plesk + Elasticsearch? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot When using "native device emoji", selecting an emoji autocomplete entry with the keyboard fails and triggers JavaScript error فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Generating phrases using an add-on فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Node link URL Please enter a value using 50 characters or fewer. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Using FontAwesome icons in user banners فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Third Party Libraries using FA فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Using XenForo With Cloudflare فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading from XenForo 1.5.12 to 2.3.7 using PHP 5.5 and 8+ فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Using the editor in my own template فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Using BBCode in a template فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to get id of token when using tokeninputrow in form فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot When using ARTICLE threads, the og:image is missing or incorrect فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Cannot merge posts / move threads using inline moderation فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What Stripe API Version Should I be Using? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Recurring Subs Error Using Stripe فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Mod with no permission to ban can still ban using the spam cleaner فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Using PHP in posts/articles... فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Assets are not copied from style archive when using symlinks فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Using the alert handler... فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Forum not using S3 after import فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Sharing tips on using Exiftool for existing forum images فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Using Spam phrases to send external URLs to approval queue but want to allow internal URLs to be posted فیدخوان خبری از سایت xenforo.com 0
