درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Hidden folder, posts within not hidden ایجاد شده است. این موضوع تا کنون 86 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Hidden folder, posts within not hidden
So, I'm not sure if this is a bug, or a feature, but it's a bug to me!
I created a node and did not include it in the directory by unchecking "Display in the node list". I did this because I wanted to post a number of story contest entries ahead of the midnight deadline so that at midnight, I could simply make the folder visible, and the contents.
Well, imagine my surprise when I double checked my work, three stories in, when I logged out as an Admin and logged in as a regular user and...
XFFA.IR Bot H1 hidden فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Embedded content and solutions from ignored users aren't hidden فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot MG - Report, Edit and Delete windows are hidden behind the displayed image فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot PWA Install line/button hidden for some devices فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there a way to have "hidden" moderators? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Token input placeholder is not hidden when entering a token فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot 403 Error for Links of Hidden Profiles فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hidden posts viewable in list فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Move Threads alerts users even if thread moved between hidden forums فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hidden threads. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to show number of hidden users فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Need an option that allows individuals to be hidden in sites search and only allow themselves to find and search themselves فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot SVGZ logo hidden if screen width is too small فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot This list contains advanced options which may be hidden. Enable advanced mode. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot how to hidden report center history for moderator فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Any hidden features of MG for XF? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image hidden in Spoiler shows in Latest Activity preview فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Need help . Hidden content (reply to show link) . What add-on this فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Class "js-attachmentAction" needs to have overflow hidden like the "file-info" class in the attachment overlay فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot xf_user_alert hidden content فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hiding posts to a hidden node. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Latest activity shows some hidden content behind [SPOILER][/SPOILER] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot The gradually hidden text issue. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Select-to-quote menu can be hidden underneath mobile browser's text selection toolbar فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [BS] Hidden content BB-codes [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Easiest way to make 1 forum visible and the rest hidden, on a per user basis. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How batch delete hidden posts ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Draft button is only hidden from editor but is still usable فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Allowing Access To A Hidden Forum فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Problem with js folder not being included in release process فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Attachments folder outside of public_html فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot File and Folder Permission Structure فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Compressed images filling up server space in temp folder فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot No Folder for the API فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot accidentally deleted internal_data folder, don't have backup... فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading to 2.2.14 reset asset folder فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot No matter what folder ffmpeg is in, I keep getting open_basedir error!! فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot syntax for moving forums from folder to root فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to setup forum in a sub folder فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Change folder store attachment فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is it safe to delete insides 'templates' folder? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF 1.5 - Attachment folder size, Database bottlenecks, and 503 errors. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot My INTERNAL_DATA folder has increased from 31GB to 150GB due to duplicate attached files فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo Importers 1.5.0 requires the presence of data/attachments folder even if no attachments there. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Moving from subdomain to maindomain: Copy Xenforo-files into public_html folder? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to move Xenforo from root to folder? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot 'Target File Already Exists' when trying to transfer 'upload' folder to FileZilla new directory. فیدخوان خبری از سایت xenforo.com 0
