درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام How to create an invite forum \/ private forum with forms or invitation? ایجاد شده است. این موضوع تا کنون 194 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع How to create an invite forum \/ private forum with forms or invitation?
Hi Guys!
I want to create a 2nd forum for a selected user group / or a private node. The thing is I know the selected group but Im not sure what's the best way to do it.
First thing: should I create a 2nd forum and with Mulisite System sync the login data and give them extra permission?
Or simply a restricted category?
How should I filter the selected group from the users? What's the best way to do it? Forms that they have to fill in if they want to participate? If so how to do it...
XFFA.IR Bot I want to use AI to create a daily podcast summarizing a days threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Visual Site builder/Page builder: create, edit, layout, design, format pages فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot TypeError: Jose\Component\Core\Util\Ecc\PrivateKey::create() فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot API Create Thread HTML Content فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to create points feature and convert it into Money فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot API: How do I properly create versions with correct release date? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to create "New Threads" in this strip فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Does Xen offer an API with an endpoint to create users, فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I need to create a button for marking the forum as read.. question about the date tag at the end. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [OzzModz] Bulk User Create فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I have Xenforo Forum Source Code but it has not opened to create an account can you help me? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to create custom bbcode this way? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Method em()->create return hint incorrectly فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot create a social فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Create an AI sandbox for customers, trained on the XenForo codebase فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can't create multiple instances of connected account provider type XenForo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Cannot create Windows Hello passkey فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XF 2.3] Webhooks --> Create Topic using Webhooks? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can't create a media gallery post فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How hard would it be to create the following link? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to create a blank style (guide) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF v2.2.13 Imagick Error with PHP 8.2 - can't create threads, reply, or message فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Seeking dev to create RSS importer that limits characters and amount of feeds imported at once فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is it possible to create custom BBcodes in version 2.2.x? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Push notification when I create a new thread فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to create a forum skinned page for custom content. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Create thread and set older date? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Trying to run "php cmd.php xf-addon:create" Uncaught error. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to create WebP reaction icons? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to create a custom CLI command for an add-on? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Seeking developer to create minimalist style and install Addons for newly migrated forum فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Adsense: Create a GDPR consent message by January 16, 2024 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Create an option without showing it on the admin options page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to create custom api endpoints? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can I pay someone to give me the code, or create an addon, that will limit the length of URLs? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Minimum posts to create conversation? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Create your own video tutorial فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do we create an add-on that contains only template modifications? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Access denied when php cmd.php xf-addon:create فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do I create hashes.json for changes in an addon فیدخوان خبری از سایت xenforo.com 0
