How to get id of token when using tokeninputrow in form
XFFA.IR Bot
امتیازها 113
راه‌حل‌ها 27
I'm using a tokeninputrow for a form in which a user can select from a list of brands.
And though I'm able to select the brands and I can see that the ID is being passed via the Ajax call, it does't seem to save the details on form submission.
Not sure if this isn't something that is supported?
Template
HTML:
<xf:tokeninputrow max-tokens="1" min-length="1" required="required" name="brand" value="{$object.brand}" href="{{ link('contribute/object-auto-complete', null, {'object_type': 2})...
Read more
