درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام How to understand and modify color codes? ایجاد شده است. این موضوع تا کنون 37 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع How to understand and modify color codes?
Hi, I'm trying to modify theme colors in Basic colors, where specific XF coding is used, like "darken(@xf-textColor, 35%)". But when I click on it, I cannot see exact colors I would like to have, like #2d3037. Even the Picker is a lot of trial and error to get close to what I want. And then I can't save that to also use it elsewhere.
Is there a tutorial showing us how to create our own re-usable colors and save them as presets to be re-used?
Thanks! :)
XFFA.IR Bot Trying to understand indexing vs rebuilding cache فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Confirm understand rules before posting topic فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I don't understand how can I get a link to a banner in order to place it on the background of the page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Important places to note when you need to understand template extensions, and how they get used practically. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I do not understand anything about Xenforo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Understand macro extension فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to Properly Modify CSS Files? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do I modify Notable Member categories? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot modify navigation فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Modify the user block on the left of threads/comments فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to modify a template for a specific style فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to modify user edit admin template? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How Can I Modify the "Replies/Views" and "Last Post Timer" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to modify template with html that changes فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot do_not_have_permission error when requesting to modify a post فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Switch from dbtech [MENTION] bbcode (vBulletin) to [USER] xF2 - A simple query modify فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Modify approval queue rules for threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there a widget or way to modify profile page? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Modify column width on thread view for all sizes فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to modify the template of a specific widget? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Any way to modify image code output? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to modify user banner template? Does one even exist? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do I know which template to modify? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to modify BB Code for Spotify? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do I find the app_user_banners.less template so I can modify it? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Modify push notification time فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should we modify an add-on's template directly or should we use template modification? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Modify [img] to accept gifv? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenTheme Theme Color Picker [Deleted] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot PWA Icon background color ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Where is the row color defined ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Color change question on Whats New فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot username color فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Border Color change فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to change color of the Plus and Minus symbols? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Link color for thread titles in forumlist nodes فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Tag color change please فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to use the same color for "structItem-parts" items? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How can I change color of page numbers? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot link color only post فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Group color فیدخوان خبری از سایت xenforo.com 0
