Image attachments are not visible in custom terms and rules thread if forced to re-read terms
درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Image attachments are not visible in custom terms and rules thread if forced to re-read terms ایجاد شده است. این موضوع تا کنون 114 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Image attachments are not visible in custom terms and rules thread if forced to re-read terms
So, if I change terms and rules default link to my own one (for example, to some thread), force users to read & accept them one more time, then, if user goes to custom thread, he won't see any attached images till he accepts terms again. That's a definitely bug and, can be avoided manually by adding required attachments to ignore list, but, instead, it probably should be fixed in xenforo itself
XFFA.IR Bot Image Proxy tries to proxy attachments فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Attachments insert full image automatically? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Load Image Attachments Directly from S3 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Cloudflare + Image Attachments فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image Attachments Display فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can we rebuild/resize image attachments after changing "Maximum attachment image dimensions"? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Paid request: addon to show EXIF information of attachments in an image overlay فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image embed limits not working - interpreted as attachments instead? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image attachments after upgrade from XF1 to XF2 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Xenforo 2.1.9 cannot copy and paste to hotlink images from clipboard with image attachments turned off (worked in 1.5) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Ability to upload image attachments in signatures فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Automatically inserts image attachments فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Allow quoting of image attachments فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Uploading image attachments via URL (HTTP) leads to "Uploaded file is too large" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image Attachments Importing from IPS 4.4.10 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What's the best way to disable attachments and allow quick remote image upload? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Some image attachments not displaying فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Grab Article image from Attachments if there is no image in the article فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add option to disable "Full Image" when inserting attachments فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Thread prefix image فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Missing Image Button in Signature فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there a way to get an image for og:image" content= per page node? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot how to search an image posted on my forum? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XFA] Profile Background Image Customization [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo 2.3: Broken image uploads in Firefox with "privacy.resistFingerprinting" = true فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image Title فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot logo URL image not loaded in derived/inherited child style فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image saving issue فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot OG:Image not working فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Whitelist of image hosts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image optimization: GIF to Webp, What are the required libraries on the server? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image next to usergroups? (image given) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to use an image with variations as a background image فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image in Featured is not responsive فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image proxy curl timeouts for slow image hosts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Avatar Approval System and Image Hosting فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Closing lightbox scrolls document to last viewed image فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to add an image to a category? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Notices Page Critera: Page information (For Display image) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image compression rate? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot When uploading an avatar the selected image disappears فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot meta tag system og:image فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Default image for trending threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Maybe a bug in image/edit/preview function فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Oops! We ran into some problems. Provided file is not a valid image. فیدخوان خبری از سایت xenforo.com 0
