درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام IP\/subnet blocked should not cause soft bounce (hotmail, live, outlook) ایجاد شده است. این موضوع تا کنون 50 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع IP\/subnet blocked should not cause soft bounce (hotmail, live, outlook)
There are several situations where soft bounces is received for perfectly valid email addresses.
This happens quite often with email providers like Microsoft which has its own sender reputation system. (hotmail, live, outlook, custom domains, etc) Microsoft hosts about 25% of all email so this issue has high impact. Especially for big boards.
Here are some of the situations which often occur:
  • IP rate limited. This happens when you send out a lot of email or trip internal email...
XFFA.IR Bot Users Getting Blocked Due To ModSecurity فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot copy & paste of image to make an attachment is blocked as webp isn't an allowed extension by default فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Blocked users should have read permissions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot was blocked due to MIME type (“application/octet-stream”) mismatch فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to filter threads blocked from search indexing from showing ad code! فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot 3k+ 'Blocked due to other 4xx issue' in Google Search Console فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Push Notifications Blocked فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot IP Blocked by Cloudflare فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot admin.php blocked(hide) ip فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User being blocked from my site by Cloudflare فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Mods cannot see blocked profiles فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Adding a resource blocked by an internal server error فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Why is gmail blocked فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot "Push Notifications Blocked" message فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there an email bounce block list/blacklist/blocklist? Or is the only record the user state change? Can accounts be blocked for bounced emails? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Valid Gmail addresses are currently blocked in they have three or more periods in the username part of the email address فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Elasticsearch indexing error (queued): blocked by: [FORBIDDEN/12/index read-only / allow delete (api)]; فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Old Usernames blocked from re-use فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Elasticsearch indexing error: Elasticsearch bulk action error first error: blocked by: [FORBIDDEN/12/index read-only / allow delete (api)] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Link to rejected and blocked users account on message فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Share your blocked email lists. فیدخوان خبری از سایت xenforo.com 0
xenforyou Ban thread - topics with blocked users افزونه های مدیریتی 0
XFFA.IR Bot XenVibe Update: No More Renewal Fees + What Style Should We Build Next? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What should I do? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should I extend my license (!) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Method XF\BbCodeRenderer\Html::getValidUrl should be in a utility class فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot \XF::asVisitor should use phpdoc template for return type hint. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should XenForo switch to Node.js or similar for a modern live responding interface? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Polls should be allowed in Question forums فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Error S3150 is processed as soft bounce. Should be an Error فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What XenForo 2.3+ Should Build Next for “Web 3.0”-Ready SEO فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Widget refuses to show on homepage but it should. What am I missing? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot When editing a post, the quick reply should be hidden. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should I renew? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should the Resource Manager items have a Media Gallery ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How should the "Ignore" function work? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Spoilers should have a limit فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should I allow /attachments/ in robots.txt? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should google be indexing individual posts in a forum? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What Stripe API Version Should I be Using? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should I Use an NDA With Any Hired Developers? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Video attachments should be opened in lightbox فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot The ACP is too obscure. Example: the Test Outbound Email page should link to the page where you can send a formatted email to test branding, logo, etc فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Display results as threads/grouped should be the default فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Very important - Emails should not contain images (NSFW) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Either 'text', 'image' or 'video' should be specified (Errors in Google Search Console) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Discussion forum structured data - articleBody should be changed to text فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Functions which use func_get_args should be typehinted with 'mixed ... $arguments' فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Threads created by a report should have any custom thread fields available to the user. فیدخوان خبری از سایت xenforo.com 0
