- تاریخ ثبتنام
- 2020-06-26
- نوشتهها
- 24,138
- راهحلها
- 27
- پسندها
- 3,277
- امتیازها
- 113
- سن
- 28
- محل سکونت
- England
- وب سایت
- xenforo.xyz
Usually we use template edits to add html to certain things.
I have created a "resource field" and I wanted to add a search bar on top of the resource field as it has a super long list of check boxes. The problem is, I can't find a way to specifically add the html on top of this particular resource field. Whereas when we create widgets, a new template is made for that particular widget, we can't do this with resource fields.
I tried doing template modifications and do find and replace but...
