درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Is Less actually More? ایجاد شده است. این موضوع تا کنون 122 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Is Less actually More?
I've owned three successful forums over the last 15 years and I've found over time that despite my penchant for wanting to add every add-on I could find or "turn on" every stock functionality, they didn't help in the overall growth very much. I'm talking about front end functionality not back end helpful admin stuff. Also, in terms of visual aesthetics, I've also found that less is more and I struggle with this too. I have another new forum now that I have to keep reminding myself to keep...
XFFA.IR Bot Is Less actually More? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Style variant LESS/CSS not working for "system" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot LESS lighten/darken functions no longer work as expected فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Less templates appear to be in strict maths mode (ie more parentheses) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Dead code in setup.less and many other less templates فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Please enter a value with 16 chars or less! فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot core_utilities.less spaceBefore incorrect margin فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Indent BB code is auto-inserted when max-width and auto margins are defined for p in “editor.less” and list BB code is applied فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot To less alcohol? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Clarification on How Creating Custom .LESS Templates Work فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom .less Template Not Loading فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot If you have members who are older or less tech savvy folk, have you done anything to make your site easier to use? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot More.Less Values for Alert notification Highlighter and User Picklist فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [Accepting bids] Restrict all users with less than X amount of posts to only viewing threads newer than X amount of days فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Less error when calling certain templates فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Looking for cheap dedicated server less then or equal $30 in europe فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Less is more, more needed فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot oyejorge/less.php is archived فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF site suggestion when rating add-ons let us review with less than 100 characters فیدخوان خبری از سایت xenforo.com 0
