Issues on mobile devices with quotes (not Chrome)
XFFA.IR Bot
امتیازها 113
راه‌حل‌ها 27
Hello, since the last update when users try and reply using the quote/reply function it will give you a few seconds and then will start putting your reply in the quote box.
If you try to exit the box it will create another quote box and so on.
Chrome seems to be the only browser without this issue.
