درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام 'Leave a rating' for Resources isn't showing up for registered users ایجاد شده است. این موضوع تا کنون 163 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع 'Leave a rating' for Resources isn't showing up for registered users
When a registered user clicks on a Resource, there should be a button that says, 'Leave a rating' but that isn't not currently appearing. I have checked the user permissions and am hoping someone can help direct me to where the issue might be.
XFFA.IR Bot Show Star Rating On Overlay & Leave Review BY Clicking Stars فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Change phrase: delete instead of leave (direct message) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot The "spam clean" option is often missing from the approval queue, as is the option to leave a reason when deleting فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot RSS Feed import may leave HTML in title فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Accidentally mass messaged 1,500 users and forgot to select "Leave direct message and accept future responses" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Pulling forum - how to leave forwarding page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I figured out how to remove single line breaks on mobile but leave them on desktop فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Missing option to leave reason when deleting content via the mod approval queue. Integrate with warning reasons and rules فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot SEO: remove h3-tags from widget block titles in sidebar and leave Headlines for more important content? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Why did you leave Invision or WoltLab or vB5 or other commercial forum platform (if you migrated to XF)? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can I disable captcha for registration and leave it enabled for guest posting? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Leave Conversation bug? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Leave conversation and limit recipients فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Unattended Upgrade can leave site offline فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Redirection Notice: Do Not Leave A Redirect As Default? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Remove rating [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Star rating in thread list فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Incorrect % in rating count & the phrase appears in other languages فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XB] Thread Rating Posts [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Star Rating Updates فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Empty rating stars pretty invisible with alternate style فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Showing start rating on google search فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there something like a randomiser & image rating add on for the gallery? (hot or not style) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Star rating sytem for posts/users. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Rating Button not working فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there a star rating system for posts? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is it possible to get Customer Happiness Rating in Xenforo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot API - return media with a rating of > 3 stars فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Stars rating, no reset? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User rating system? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hide Rating Or Remove Rating System Full From xf resource manager فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Rating macro on custom page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Force rating & comment/review فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XTR] Thread Rating System [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot rating a video or photo it closes the modal? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [TH] Star Rating for Custom Fields 1.0.x (Custom Field XML) [Deleted] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot rating anonymously فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot how to change rating stars فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do I show a custom thread field which a Star rating type is used? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Show another row on rating change فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF site suggestion when rating add-ons let us review with less than 100 characters فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot change XFMG rating from "stars" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Stars rating on the google snippet فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Needed : Disable resource rating system + Disable Update title Update message فیدخوان خبری از سایت xenforo.com 0
