King فایل جدیدی فرستاد.
Limit Slug (URL) Length - محدود کردن تعداد کلمات موجود در URL
اطلاعات بیشتر در مورد این فایل...
This add-on creates a new setting under Basic Options called Limit Slug Length:
مشاهده فایلپیوست 11083
It simply does what it says, shortens the "text"-part (also known as a slug) to be withing the defined number of characters..
Note: It also shortens slugs in the admin, but this will be fine as all things are anyway using the slug.id-format so all pages will work as normal
