درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Multiple solutions ایجاد شده است. این موضوع تا کنون 194 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Multiple solutions
I thought someone has suggested this before, but I can't find any thread about it.
Is there any chance to give us ability to mark more than one answer as "solutions" in Question Forum? Sometimes people answer correctly but only partially. So it would be good to have possibility to choose more than one answer to feature full solution.
XFFA.IR Bot Multiple solutions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What's the best way to manage two user groups in a forum? (Multiple solutions: which one is the best? ) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Allowing Multiple Accounts with the Same Email – How to Configure Safely? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Report function - Multiple people reporting فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do I use the built in search for Multiple-Word Content? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple Xenforo OAuth Connected Accounts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Place a RM entry in multiple RM categories فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple email addresses فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot High volume of spam registrations even with multiple spam prevention measures enabled فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How can I address multiple usernames in an email message or alert? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot issues for multiple languages فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple finder results to API result فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple profile banners & slider فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Validation of multiple field values together فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot False positive about multiple classes declared in the same file with phpstorm & extension_hint.php فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple users have had their primary user group changed to '0' فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple prefix options فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XFES and multiple forums فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot ACP login problems - multiple requests to enter password فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Allow multiple content templates for notices فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Uploading multiple GIFs as attachments - Only 1st is animated (See zip to replicate with 2 others) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Uploading multiple GIFs one by one in XFRM فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot (Solved) Multiple License Discount? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot multiple upload button in form فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Show multiple items at once in slider / carousel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How can multiple registrations be prevented? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple polls per thread. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple Domains same install path فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot utm displaying multiple times فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot adding multiple titles to elements within same xf:button فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot As the Administrator - How to post threads under multiple different user names? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Replace Multiple with Template Replace Filter فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Importing / Merging Multiple VB 4 Forums to 1 XF فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Shared IP tab does not have stable ordering resulting in unreliable matching across multiple users فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Allow approving/deleting multiple posts in Approval queue فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to display a sticky thread across multiple forums ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple same actions in just one alert فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Passkey Auth won't remember me on multiple devices فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple reactions are badly displayed فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can't create multiple instances of connected account provider type XenForo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Ad displaying multiple times فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Installing multiple addons at once ignores addon requirements, leading to unexpected install/upgrade failures فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple files via URL فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Starting a new conversation with multiple recipients فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple External download URL فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Nginx Friendly URL Config For Multiple Directories/Installs فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot December promotion does not reflect multiple licenses holders فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Multiple Licenses فیدخوان خبری از سایت xenforo.com 0
