درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Older posts go brown ایجاد شده است. این موضوع تا کنون 64 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Older posts go brown
I often find myself reading old posts when someone comments. Would be nice if it were possible to style it such that posts over a year old start going a bit yellow, and then beige after 2 years, or something like that. Can't be hard, right?
XFFA.IR Bot Merge threads redirect to go the the top of the newer thread, not the older one. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [OzzModz] XFRM: Remove Older Downloads From History [Deleted] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Older Images Not Showing After Upgrade فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Improving SEO to compete with older forum competitor فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot PHP Callback for support older versions and new XF tags فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Create thread and set older date? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot "Show older items" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot If you have members who are older or less tech savvy folk, have you done anything to make your site easier to use? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot "This page isn't working" when attempting to install older version فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Re-number page numbers of search results after pressing "View Older Results" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Xenforo 2.2.4 -> 2.2.7 Froala Breaks in Older Browsers فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF 2.2.7p1 older IOS devices are missing reply text boxes فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Really crazily messed up article preview display on older iOs فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot 'Show older items' does not show if filters match no results in 'last X days' فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After import, some posts by Guest فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [OzzModz] View Own Deleted Posts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Timed Sticky Posts/Threads Feature فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Noob Question: Does anyone know how to change how posts look? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot instant posts live update فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [2.2.x] Staff Replies (private posts) [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Spam deleted still shows in Latest posts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Latest Posts in a Wordpress Widget فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Insert options on posts/replies... فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Twitter/X posts not embedding فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Incorrect ordering of posts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XB] Widget New Posts: Latest Threads Filter [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hierarchical Posts conversion فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to fix thread views count if posts are cached فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Permanently delete all soft deleted posts and permanently delete all profile posts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleted X.com posts - Addon Idea? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Plugin to add SEO content inside Forums and below posts? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Rank Based on Number of Posts Created for XenForo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XB] Widget: New Posts Prefix Filter [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot 'All New Content' tab on find-new (new posts) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hide Usernames/Details Beside Posts for Specific User Groups فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Smaller images in posts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Inability to move/copy threads and posts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Flagging posts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Show Reports on Threads and Posts While Browsing for Easier Moderation فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Minimum time between profile posts? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Staff Replies (private posts) [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Highlight posts in a thread? فیدخوان خبری از سایت xenforo.com 0
