درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Panel with system info? ایجاد شده است. این موضوع تا کنون 60 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Panel with system info?
Okay, my admittedly sometimes faulty brain tells me there used to be a panel on the home page of the ACP that gave stats about the underlying system like MySQL version, PHP version, and such. But I don't see it. Am I misremembering where it was? Or was it removed for some reason and I forgot that? I am logged in with my personal admin account, not a superadmin. Could that be a factor? Or am I delusional...
XFFA.IR Bot Advice on operating system and panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Statistics Panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Which free control panel do you recommend? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Admin Panel looks strange after upgrade 2.3.6 to 2.3.9 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Bulk delete rejected users from moderator panel [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is it possible just minor upgrade 2.2.8 → 2.2.17 from admin panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I have recently purchased a NAIPO 500w 48v Ebike. Need help it has no P08 in control panel. I’m not sure 🤔 if this is the correct forum to ask help فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XTR] Dynamic Welcome Panel [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I can't access the admin panel! فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Admin Panel Install/Upgrade Page #7d0f8a فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Blank Page in Admin Control Panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [Ap Yazılım] User Panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Having a hard time logging into my admin panel? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can't view IP addresses in admin panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Downloading Installed Addons from the Addon Control Panel? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [Andrew] Admin Panel Notes [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Tradionnal Chinese translation for [Andrew] Moderator Panel 2.0.9 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Member user panel dropdown to hide style selector. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can a moderator view admin panel of Xenforo? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Admin panel logo change فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Admin control panel search not finding all options with keyword فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot You must enable two-step verification to access the control panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Native Moderator Control Panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo SSO does not work for admin panel login فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Admin control panel - Phrase filter - space issue فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot kicked out admin panel constantly فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Overwhelmed by control panel - Are there more tutorial videos? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User sort in control panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Node permission update error 403 Plesk control panel ModSecurity fix فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User Registration panel is not working فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot scheduled jobs outstanding Error in side admin panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I got kicked out of the admin panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Password input field when adding user in admin panel is not type password فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Running my forums website without control panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Best control / web panel for xenforo?! فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot No admin control panel access فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Admin panel & style all messed up after add-on install? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [OzzModz] Admin Control Panel Improvements فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I can't access the admin control panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Universal Info Widget/Panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [BS] Visitor progress panel [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [Andrew] Moderator Panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Admin panel path change XF 2.2? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User-customizable Visitor Panel فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot admin panel light and dark built into default فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Admin panel - Dropdowns not clickable/working anymore فیدخوان خبری از سایت xenforo.com 0
King [XenGenTr] Visitor login and register panel افزونه های کاربردی و ظاهری 0
