درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Required custom fields doesn't work ایجاد شده است. این موضوع تا کنون 104 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Required custom fields doesn't work
I just verified that the required custom fields are not working for me. Although I have them configured as such, I don't get the "required" message when editing the post:
I have tried the following solutionse:
  • Left the extra.less template by default
  • Left the modifications of the rest of the templates as default
  • I have disabled all addons
  • I have used the Rebuild data master option with /install
And nothing has worked...
However...
XFFA.IR Bot [Xen-Soluce] Required Custom Fields On Forum [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [Xen-Soluce] Required Custom Fields On Upgrade [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Required custom field not being enforced فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom URL should be required field when selected فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What are the precise php.ini settings required for Xenforo 2.3.6? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot SSO: Please enter a value for the required field 'provider_key'. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF 1.5 developer required فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot ost being stopped because of required refreshing issue Confirm Form Resubmission فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Post being stopped because of required refreshing issue Confirm Form Resubmission فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image optimization: GIF to Webp, What are the required libraries on the server? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot PhpBB: LogicException: Column 'question' is required and has an empty value while importing XF:Poll فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot "Please enter a valid value" (for XFES and may apply to XF where whole numbers aren't required) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Zero-value 'required' choice resource fields trigger validator error فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Permissions suddenly all turned off and 2FA required? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot IndexNow error: The key field is required. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Structured data for DiscussionForumPosting: text, image or video is required فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Index now error the key field is required فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Two-step verification required فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Entity field "required"=true does not work when type if UINT فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot ViewableInterface should provide a method to get required relations for canView فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Make Location show on registration form as optional - not as required فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What version of XenForo is required for video transcoding فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Email Not Required فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Cook consent is disabled but member can't login due to "oops cookies are required" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot mbstring extension is not loaded but is required فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot PHP extension(s) 'gmp', 'mbstring' are required for push notifications support. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Oops! We ran into some problems Please enter a value for the required field 'email' فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Disable "No prefix" if they are required فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot "Cookies Are Required To Use This Site" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Posts API: Missing Required Inputs فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is curing required for AAC blocks? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot (How I will enable it)Cookies are required to use this site. You must accept them to continue using the site. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Required form element error message via phrase فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Action is required for Facebook login app فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Cookies are required to use this site. You must accept them to continue using the site. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Facebook app - acquired required on policy فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot add more required="required" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Action Required: CAPTCHA changes فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Thumbnail add-on required فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Description Required فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add more (non-required) info during registration فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot required PHP extension cURL could not be found فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot URL Rewrite help required فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot LogicException: Column 'title' is required and has an empty value while importing فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Any cleanup required after Media Gallery uninstall? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot C++ Coder Required فیدخوان خبری از سایت xenforo.com 0
DARKNESS پشتیبانی مشکل کوکی برای زنفورو cookies are required to use this site. You must accept them to continue using the site. پشتیبانی XenForo 2.x 8
XFFA.IR Bot EU pushes forward on law against hate speech, illegal content. Hosting companies required to take websites offline فیدخوان خبری از سایت xenforo.com 0
