Resource threads in forum become disconnected from Resource when the forum type is changed to Article
درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Resource threads in forum become disconnected from Resource when the forum type is changed to Article ایجاد شده است. این موضوع تا کنون 201 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Resource threads in forum become disconnected from Resource when the forum type is changed to Article
OK I'm sure this is expected or by design
BUT
It's hugely dangerous that if you change a forum into an article forum, and you just happen to have some resource discussion threads lurking away in there, then they (of course) get converted to articles and at that point become disconnected from the resource with no way (that I can tell) to reconnect, ie the process is irreversible, so is a bit of a showstopper.
So if the above is (understandably) by design then the...
XFFA.IR Bot Is there a way to add an "Add Resource" button to a forum where resource threads are generated? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Mirroring appended Files from the threads into the Resource manager? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should Paid Resource Threads Be Private or Public? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Featured threads showing "Thread" / "Resource" before title فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot CSS not applied to resource-related threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Resource threads waiting for approval are postfixed [DELETED] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Resource titles prepending 'Resource' to them in widgets? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XenCustomize] Resource Prefix Filter [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [OzzModz] XFRM: Display Resource Icon In Search Results [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XFA] RM Resource Forums [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Addon that links a resource to a GitHub repo for auto-updates? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [AKL] Resource Manager Dropdown menu فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Featured Resource Slider فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot "featured content" from resource database currently only featuring latest resources, not working in subcategories فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Get Error when I try Groups & permissions >> Resource category permissions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Remove file uploads from resource manager فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Slow file download - Xenforo Resource / XFRM فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Tradionnal Chinese translation for XenForo Resource Manager [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Disable Update Notifications in Resource Discussion Forum? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Croatian translation for XenForo Resource Manager [Deleted] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Does Resource Manager Have a Working API? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Conditional on resource field in own tab location فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to Remove Prefix from Resource Email Format? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there an option to pin a resource? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Help on Resource Limits فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Insert into top of resource category view template فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Content Ratings for XF2.1+ Resource Manager فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [OzzModz] XFRM: Resource Questions [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Template modification under specific resource category فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add resource manager options to Navigation list فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Google indexing cannot recognize my site (resource) title فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Addon to manage Resource Downloads and other stuff فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Resource Discussion Thread فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Console error, while loading add resource فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can't upload a 100mb resource فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Cannot add description when creating a resource فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Google indexing: Page is not indexed: Duplicate without user-selected canonical for the resource / rate and updates pages فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hide Resource Ratings فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Admin Vs Mods editing a resource فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Zero-value 'required' choice resource fields trigger validator error فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XFRM: Rebuild resource embed metadata ERROR فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Weird behaviour when editing a resource (admin Vs mod) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Widget only on the Resource list first page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo Resource Manager 2.3.2 - installation issue فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add Meta Description Area For Resource Homepage فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [MMO] Who Downloaded This Resource فیدخوان خبری از سایت xenforo.com 0
