Separate "Small Logo" Field for Better Icon Handling
XFFA.IR Bot
امتیازها 113
راه‌حل‌ها 27
Brief: I believe it would be highly beneficial to offer an option for a smaller icon specifically for mobile navigation. Although the code refers to "small-logo," it still refs to the same version used for the desktop logo. If you have a wider logo, it would be preferable to display a square-sized image — similar or identical to the one uploaded in the "Icon URL" field — instead of scaling down the desktop logo. (p-header-logo and p-nav-smallLogo share the same URL)...
Read more
