Server limits changing (php.ini / my.ini) to prevent load errors or speed up the process / upgrade and import
XFFA.IR Bot
امتیازها 113
راه‌حل‌ها 27
Hello all! :)
I have a question related to importing system (between two xF2.3.7 forums) and also xF2.3 upgrade from xF2.2.
Do you suggest any constant or temporary server php.ini and my.ini limits changes to speed up the process?
For example, on import-finalize (localhost / xampp), the rebuild job rebuilds Posts. This process on my localhost is very slow. It takes hours.
My question is also related to prevent errors due to low php.ini or my.ini limits.
I want to minimize process breaks...
Read more
