درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Setting maximum preview length\/widget height for Expanded View on \"New Threads\" widget ایجاد شده است. این موضوع تا کنون 168 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Setting maximum preview length\/widget height for Expanded View on \"New Threads\" widget
Hello,
I am trying to put some text content above my forum nodes on my website, to have an area for important "news" that is immediately visible to visitors.
To this purpose I am using the "New Threads" widget, located at "Forum list: Above nodes". I have it set to preview 1 article from the selected node in Expanded View, which allows me to display content directly on the main page as desired.
However, Expanded view will preview the entire article with no limits, meaning for lengthier...
XFFA.IR Bot Search forums - Maximum results setting فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting up SSO with Keycloak for Xenfor فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom Posts Per Page User Setting فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting defaults for new forums? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I need help setting up Stripe for user upgrades فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can we batch update users to follow "System" style setting? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting visibility date of birth (XF 2.2.9 Cloud) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting up Account Upgrade payments, both Stripe and PayPal فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Breadcrumbs behave differently depending on the "Use full friendly URLs" setting. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot ACP setting to delay emails triggered by replies to watched content فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting resource icon automatically depending from content type or custom field? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User Privacy Group Permissions Setting فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting a checkbox custom field value فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XFES ignores setting searchMinWordLength فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting user promotion not work on certain users? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Having problem setting permissions. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Does setting a forum to show threads from last 30 days affect SEO? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there a setting to enable the new ratings layout in XFRM? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Paid: Need help setting up my website فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What setting for BB Code Elements controls text color? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Calendar Day, Month, Year Format - Is There No Setting for This? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting up static pages (html or other) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Gallery index slow when changing a setting فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting default prefix فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Detailed startup guide for newbies on migrating to, and setting up a Xenforo forum. Including reddit-like titles, and threaded comments. [Centmin Mod] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting threads to "private" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How should I remove this setting for bold in unread threads? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting Custom "User Group Leader" Permissions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting MG Image display size فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting a custom preference from a template فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting the slider carousel timing فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to keep radius setting for Tab Menu when scrolling ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Language, setting for users? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Profile Setting: Automatically Theme Change per daylight/night فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Cannot find "Path to Images" setting within ACP فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot where is the location of contact address e-mail setting? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Mod/Admin setting to turn off downvotes per-thread فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting XF1 template variable based on nested ternaries فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Pros/Cons of using CDN URLs with XF instead of setting up a CNAME & SSL cert for actual domain? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Help with setting up my site فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting up email فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hello - beginner setting up فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Setting default visibility for flysystem via config.php فیدخوان خبری از سایت xenforo.com 0
