درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Similar Threads - does it reduce posting? ایجاد شده است. این موضوع تا کنون 213 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Similar Threads - does it reduce posting?
Before upgrading to Xenforo 2.2, I had a Similar Threads add-on that would only show the similar threads when viewing a thread or after posting a new thread. The new version shows similar threads as you type.
My concern is two-fold:
1. It might discourage the creation of new content since they could abort their intended post
2. When you start typing your title for a new thread, you get the similar threads list below that title, although it doesn't label them as similar threads. I wonder...
XFFA.IR Bot Does the new 2.2.0 B1 'Similar Threads' widget use the threads titles? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Similar Threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Similar threads: add weight to title matches فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Text Reply Box & Similar Threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Forum Email Broken; Similar Threads Broken فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF 2.2 Bug? Forum Email Broken; Similar Threads Broken فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot More of a UX issue with Similar Threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot No Similar threads dropdown heading فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I am having errors showing up with 2.2 with similar threads enabled. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [BS] Similar threads افزونه های کاربردی و ظاهری 1
XFFA.IR Bot افزونه 2 AndyB Similar threads دانلود افزونه های XenForo 2.x 15
XFFA.IR Bot Prevent Similar Nicknames فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After a license picker similar to printables فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Anything similar to WP Custom Taxonomies? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Enhanced Search - Similar Thread Caching فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Themes similar to Circle.so or a Facebook group فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Disable similar thread suggestions. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Feed page (similar to Reddit) فیدخوان خبری از سایت xenforo.com 0
