درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Soft deleting threads in forums by users who get removed from a usergroup? ایجاد شده است. این موضوع تا کنون 120 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Soft deleting threads in forums by users who get removed from a usergroup?
We have some forums where only certain usergroups are allowed to post threads. The problem is, some users are removed from those usergroups but their threads remain live in those forums. I'd like to figure out a way to soft delete those threads when the thread author is no longer in a usergroup with permissions to post new threads in a given forum. I'm not sure the best way to go about achieving this.
My first thought is to create a cron job that runs nightly and checks all the threads in...
XFFA.IR Bot Permanently delete all soft deleted posts and permanently delete all profile posts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Convert soft bounce to hard bounce فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Yahoo Email Bounce, Hard vs Soft فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Copied text is pasted as a block / Soft line breaks included in copied text فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Undelete soft-deleted resource version - not possible? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XTR] Soft Deleted Items [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Soft delete dont work فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there any soft delete option for tags? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot soft 404 of sitemap فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Soft delete album, pictures still visible فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Adding/removing a media item in a soft-deleted album should not change the media count فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Soft delete all moderated posts (queries) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting conversations فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Batch deleting spam accounts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting a custom user filed does not update xf_user_field.custom_fields فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Error when deleting paying profile فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can't reinstall XenForo after deleting the database directly فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot When deleting users… فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hard deleting thread with unapproved posts does not update approval queue فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Superseded prefix when deleting a review فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting all threads/posts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Possible to remove the necessity for users to fill in a reason for deleting a post? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting unused avatars فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Putting Latest Posts back in Widgets after deleting فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Redirect after deleting posts? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Errors since deleting DB Table 'hdrcgbwe_xf.import_log_vbulletin5_1' فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting private conversations / direct messages فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting media فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Allow approving/deleting multiple posts in Approval queue فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting an email address - can member still log in? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Approval queue - need to give a reason when deleting a post فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting a widget does not delete its title phrase فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting all data فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting posts before a specific date, while excluding posts from specified subforums فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can an add-on be uninstalled without deleting its data? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Missing option to leave reason when deleting content via the mod approval queue. Integrate with warning reasons and rules فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Defined and custom reasons, sent when deleting posts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting custom thread fields - I don't think the current functionality is good. It makes them risky to use so I don't use them for anything important فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Database error when hard-deleting a thread after upgrade فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot MySQL Query for Bulk Deleting "Last Edited" Dates? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting the HISTORY of a convo or a post فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot self-deleting thread فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Removing reactions when deleting a user فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting replies having quoted a deleted post فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting a parent node with large amount of child nodes causes allowed memory size exception فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Don't reduce post count after deleting posts / threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After deleting and rebuilding parent node, torrents automatically hide themselves فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After deleting a post, it redirects you to home/root page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting Ratings فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Deleting a Title Name causes big problems فیدخوان خبری از سایت xenforo.com 0
