درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام SQL for largest time difference between consecutive posts ایجاد شده است. این موضوع تا کنون 29 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع SQL for largest time difference between consecutive posts
Can anyone think of some SQL to answer the question of "what's the longest time between postings on a thread?"
i.e, which thread has the greatest time difference between two consecutive posts?
For example, thread x has a 18 year gap between posts 3 and 4, and thread y has a 21 year gap between posts 326 and 327 - thread y would be identified as the largest post time gap.
XFFA.IR Bot Slow pagespeed LCP (Largest Contentful Paint) for pages with notices / cookie warning فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to Fix Largest Contentful Paint فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What's the difference formAction etc? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What is the difference in these find calls? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Title font difference on mobile? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there a difference between uploading a video in a post and uploading a video to XFMG فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Difference Between an Attachment & Insert Image فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User banned display difference between user فیدخوان خبری از سایت xenforo.com 0
