درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Text cursor and problems with smilies \/ emojies (xf:editor) ایجاد شده است. این موضوع تا کنون 47 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Text cursor and problems with smilies \/ emojies (xf:editor)
Hello all!
I recently upgraded to xF2.3.7.
There is a problem on the xF2 editor on my forum, but I can detect it even here on xenforo.com.
The bug: If I select a smiley from the smilies menu / list while writing on the editor, I can't turn the text cursor in front of that smiley, for example for changing sth or add new text. The cursor stacks in front of the smiley -1 position from the smiley.
Example:
test :coffee: -> I cant't move my text cursor in front last "t" while no other chars...
XFFA.IR Bot Cursor stays on same line if enter is pressed after text is entered (Gboard) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Cursor stays on same line if enter is pressed after text is entered فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Cursor moves on backspace when there are multiple lines of text. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Selected Text background color? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Correct text & formatting function (AI) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot A way to search for all posts containing <text string> posted by Anonymous? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XB] Text to Speech [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot unexpected behavior - for buttons with text including phrase icon فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Prevent the great wall of text (force line breaks, punctuation) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there an addon that no-indexes notices? (things like affiliate disclosure notices appearing on every page and other not UGC text?) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Random occurrences of almost-black text noticed in Dark mode? RGB(20, 20, 20) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Bring back unlink all text function فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Rich text editor keeps going to inactive mode. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Button text color - only one button فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Minifying HTML to improve low text-to-HTML ratio فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot The text must not translate into the box where you write posts or treads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Getting Custom User Field Text فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Featured text fading? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [solved] How do I edit the cookie usage text? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Disallow Russian text? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot extra.less Replacing text with image that redirects فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After sending DM, sent message text shows as draft in next message text box فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Adding Text to Registration Form فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Inline Code Tag Doesn't Span Across Text with Line Breaks فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Either 'text', 'image' or 'video' should be specified (Errors in Google Search Console) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Discussion forum structured data - articleBody should be changed to text فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Invalid selectors and other issues in editor.js cause pasted text not to be normalized فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Colour change of navigation forum landing page text فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [xF-addons] Text Logo [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Update xf_user_group/banner_text to varchar(255)~ & ACP > Groups & permissions > User groups > Edit "User banner text" max chars limit to reflect فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Changing Text on parent navigation menu فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Use text instead of logo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Password to Elastic Search is shown as plain text in Server Error Log فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Different Font for Header Text? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hide navigation text title "Home" but keep the icon فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Search (batch update) users who have not filled out a specific (text) user field فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom post thread button text فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to Add Text to Login Page? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot No reply box text editor with Brave browser, PC and mobile فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Formatting When Copying Text with HTML into Editor فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Prefixes in article forums (only) have bold text فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to add text by the date in posts? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Convert a text box to drop down custom field فیدخوان خبری از سایت xenforo.com 0
