درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام To less alcohol? ایجاد شده است. این موضوع تا کنون 54 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع To less alcohol?
Maybe i need more drugs or alcohol ... there are things inside XF i cant understand without such support. :)
I have a new field xf_thread.lala
I do a dump in a template with {{dump($thread)}} and i have my new field lala with value 123 inside the dump.
then i do {$thread.thread_id} and i can see my thread_id;
then i do {$thread.lala} and i cant see my field lala.
How it is possible that xf_thread.lala can be in my dump, but not in $thread.lala?
Is there any sense, is there any...
XFFA.IR Bot Style variant LESS/CSS not working for "system" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot LESS lighten/darken functions no longer work as expected فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Less templates appear to be in strict maths mode (ie more parentheses) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Dead code in setup.less and many other less templates فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Please enter a value with 16 chars or less! فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot core_utilities.less spaceBefore incorrect margin فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Indent BB code is auto-inserted when max-width and auto margins are defined for p in “editor.less” and list BB code is applied فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Clarification on How Creating Custom .LESS Templates Work فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom .less Template Not Loading فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot If you have members who are older or less tech savvy folk, have you done anything to make your site easier to use? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot More.Less Values for Alert notification Highlighter and User Picklist فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [Accepting bids] Restrict all users with less than X amount of posts to only viewing threads newer than X amount of days فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Less error when calling certain templates فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is Less actually More? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Looking for cheap dedicated server less then or equal $30 in europe فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Less is more, more needed فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot oyejorge/less.php is archived فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF site suggestion when rating add-ons let us review with less than 100 characters فیدخوان خبری از سایت xenforo.com 0
