Unparsed tags render smilie replacement text in unknown tag options
XFFA.IR Bot
امتیازها 113
راه‌حل‌ها 27
For example;
On edit is rendered as;
If the simile has multiple mappings, this may result in unexpected (and undesirable) changes to tag's option data.
The issue is in renderUnparsedTag which uses renderString without stopSmilies/plain/treatAsStructuredText being set when rendering the tag.
PHP:
public function renderUnparsedTag(array $tag, array $options)
   return...
Read more
