درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام User's can't reply when using CDN for .js ایجاد شده است. این موضوع تا کنون 39 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع User's can't reply when using CDN for .js
We've been using a CDN for several years to load images and .js and have it configured in the config.php file. This worked until upgrading to 2.3 and then started getting some users reporting they could not reply to posts as seen below.
I've not had any issues on Iphone, Windows, Android etc myself, and it seems only to impact a few users. Any ideas about what is causing this?
Not using the default them, but it's always worked until 2.3.
For now, I've disabled the CDN for the JS folder...
XFFA.IR Bot Allow user to quote reply from a forum where they have only have viewing privileges فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Allow only OP and certain user group to Reply to threads? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Conditional if user has reply the thread فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Thread Reply Ban - Per User فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Remove quick-reply message-cell--user only on thread_view template فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User given thread reply ban can still post in thread فیدخوان خبری از سایت xenforo.com 0
King [cXF] Reply to User افزونه های کاربردی و ظاهری 1
XFFA.IR Bot Retrieve user group information via API فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot adding resources to the user profile فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XB] User Upgrade Custom Cost Amount [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Tradionnal Chinese translation for Login as User (LAU2) 1.2.9 - XenForo 2 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom User Title Badges فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User Banner Rank Bars فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Update xf_user_group/banner_text to varchar(255)~ & ACP > Groups & permissions > User groups > Edit "User banner text" max chars limit to reflect فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [OzzModz] Send Conversation/Direct Message Upon User Upgrade [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Icons and user titles فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Automatically disable all email notifications when user status is "Guest" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XTR] User Stats فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User Upgrades فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Optional custom user field on registration فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Change user register date [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User showing as "guest" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there still no way to search a user's removed content? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Change colour of user mentions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Permissions based on a User Value? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XB] User Upgrade Coupons [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Mass Move User Threads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom User Field On Registration فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Search (batch update) users who have not filled out a specific (text) user field فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Question about Time Limits on User Group Permissions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot API endpoint: Find a User by Criteria فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot UI issue — User tag pop up instead of drop down in some cases? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User promotion running fine on users, but not on admin user فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [OzzModz] ACP User Notes [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How can I avoid user group promotion if an upograde is active? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Slow Page Loads On One Site, For One User فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [OzzModz] User Thread Counter فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XFCoder :: User Vouches [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User Group Demotions? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User defined "BB code media site" not working فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Member user panel dropdown to hide style selector. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User Group permissions Question فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User Title Viewing Permissions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do you make a user an administrator? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [TH] User Criteria [Deleted] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Issue with Emails in User Upgrades - Showing “invalid@example.com” in Stripe فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom Posts Per Page User Setting فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Two Separate Sites One User Table فیدخوان خبری از سایت xenforo.com 0
