- تاریخ ثبتنام
- 2020-06-26
- نوشتهها
- 21,417
- راهحلها
- 27
- پسندها
- 3,264
- امتیازها
- 113
- سن
- 27
- محل سکونت
- England
- وب سایت
- xenforo.xyz
I added the media widget to my site and was trying to move it up and down but I can't figure out how it works, I thought it was by using the = or - under display position but the position doesn't change no matter what number I add to the box(s)
Is there a section in the manual that shows me where the widget will show up? IE Forum List: Above Node, Member Wrapper: Sidenav. Some are clear but others are not so much, if it is just try and see what happens I can do that as well.
نام موضوع : Widget position using +/-
