درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Xenforo 1.5 to 2.3 - VERY large forum with complexities ایجاد شده است. این موضوع تا کنون 102 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Xenforo 1.5 to 2.3 - VERY large forum with complexities
I’m on the hunt for a highly experienced developer to tackle the complex task of upgrading a forum from XF 1.5 to 2.3. This isn’t your average upgrade—it’s a beast. The site currently relies on a custom bridge that integrates WordPress posts into the XF 1.5 forum, and that bridge is now obsolete. The challenge lies in migrating those posts to a new, supported bridge while ensuring nothing breaks in the process. Oh, and did I mention the forum has nearly 300,000 users and close to a million...
XFFA.IR Bot Looking to move very big and old SMF forum to xenforo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot CloudFlare security systems on! XenForo is under attack too? How is your experience with CloudFlare? And KnownHost? I had a very bad one here to share فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Xenforo database suddenly grows very quickly فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Xenforo.com loads very slow فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Integrating Xenforo registration with CRM فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo + LiteSpeed + Redis + Cloudflare Optimization – Is this configuration correct? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot If XenForo's finished, what's next? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to Drop Xenforo (code) into Wordpress Site? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo XML to PO convertor فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can XF convert Invision to Xenforo? Get a quote? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Some Gen Q's About Xenforo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot New to Xenforo Returning to forums after 13+ years. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Using chatgpt to create addons for Xenforo? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What XenForo 2.3+ Should Build Next for “Web 3.0”-Ready SEO فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Blokhane - Ember | Dark Minecraft Xenforo Theme [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Blokhane - Ember | Dark Minecraft Xenforo Theme [Deleted] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot MusaPekel FindNode – Smart Forum/Category Search Widget for XenForo 2.3 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Looking to buy XenForo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo bounce processing fails to process Complaints / Abuse reports فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Solved: Recommend a simple self-hosted audio player to embed in a Xenforo 2 page? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Login Error After Upgrading from XenForo 1.5 to 2.x — Works Only After Refresh فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot At last! DPreview.com moving to Xenforo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Looking for someone expert to import VB 4.2.2 to XenForo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot OAuth2 between 2 xenforo forums فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Which database is a recommended option for Xenforo, MySQL or MariaDB? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo Resource Manager Turkish Language Patch فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to make a XenForo forum private (no guest access) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot EnhancedSearch > ElasticSearch on Xenforo Cloud فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Constant outages with xenforo hosting فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Geo-target xenforo cookie consent banner? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Cookie consent - Google Privacy & messaging CMP + xenforo cookie banner? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot PAID WORK! Looking to Hire a XenForo Developer to Customize My Forum Layout & Features. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Keep aspect ratio in Thumbnails in XenForo Media Gallery? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot (LLMO) SEO indexing on XenForo 2.3.7 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Slot Machine For Xenforo [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo Free Lite Theme فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot After import from vBulletin to Xenforo all posting timestamps are one our off فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Moving content to a different XenForo forum. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XenTurka] Customize XenForo Header and Navigation Areas فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What's the best way to translate Xenforo in 2020? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to keep XenForo node icons static? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Photopost to XenForo Media Gallery فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can XenForo be used to develop into a professional e-commerce website system? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Need Help Getting Site Back Online - Older Xenforo Version فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to Update Xenforo? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Are there AI add ons which can be used on the Xenforo platform فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can xenforo work with wordpress and with a wordpress plugin dokan? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot vBulletin board imported in XenForo: what areas are important to test? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XenForo 2.2] Aurora theme [Deleted] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo lifetime support is not life time. فیدخوان خبری از سایت xenforo.com 0
