XF2.3's XF.ajax behaves differently depending on HTTP method for handling data argument
XFFA.IR Bot
امتیازها 113
راه‌حل‌ها 27
In XF2.2, XF.ajax supported GET method using $(form).serializeArray() for the data argument. In XF2.3 this fails when using the replacement method XF.Serializer.serializeArray.
Both versions of serializeArray produce the same output format ie;
JSON:
{name:'foo', value: 'bar}
In XF2.3, XF.ajax use URLSearchParams to encode the arguments for GET which doesn't support serializeArray output format.
JavaScript:
async ajax (method, url, data = {}...
Read more
