درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Dockerized XF successfully run for hours then, errors occurs (not able to login, etc.) ایجاد شده است. این موضوع تا کنون 187 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Dockerized XF successfully run for hours then, errors occurs (not able to login, etc.)
Hello everyone,
I'm running xenforo in a docker environment launched via docker-compose, I also use S3 to store the files (internal_data and data) and Cloudfront as reverse proxy for S3 and also to a simple VPS :
My dockerized env is very basic : Nginx + PHP + MySQL + Redis
Everything works fine but after a few hours errors start appearing : I can no longer connect to ACP or my XF forum (I have to try again several times).
Here is the stack trace :
An exception occurred...
XFFA.IR Bot PayPal Legacy vs New PayPal - anyone migrate while supporting legacy subs successfully? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Have bots successfully solved rcaptcha? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How many admins here run more than one XenForo community? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [PROBLEMS] Cron <root@hosting> /home/USER/xenforo/cmd.php xf:run-jobs فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can't force whenSaveable to run after save فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Anyone else run a BBS back in the day? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to run JS also in a popup? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to get my background image to run through the header and footer فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Has anyone needed to run multiple concurrent jobs at once? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Translating Xenforo threads, does anyone run a multi-language Xenforo site? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Do any of you guys run XenForo on only a LAN/VPN? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF\Db\Exception: MySQL fetch error [2014]: Commands out of sync; you can't run this command now src/XF/Db/AbstractStatement.php:230 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot unable to run elasticsearch فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Elasticsearch 8.13.2 admin.php?enhanced-search/optimize as it suggested i should run it فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Have you run into issues with users avoiding your forum? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Run query on user downgrade فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How often do you recommend ES optimisation is run فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there a list of CLI commands to run the rebuild caches routines? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Run Jobs فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Trying to run "php cmd.php xf-addon:create" Uncaught error. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Do enqueueUnique jobs with the same uniqueId run concurrently? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Best practices to run a fresh new server ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to run single delete query in template فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Problems connecting to MySQL 8. Anyone run into this? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Facebook video won't run فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrade step did not run on fresh install فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot There are scheduled jobs outstanding which have not run. Jobs may not be getting triggered when expected. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How run addon code when user registration is complete and/or approved فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot There are scheduled jobs outstanding which have not run فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Windows 11 to run android natively - implications ? opportunities ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can't a Enhanced search / similar thread run without Elasticsearch? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Thread triggers adblockers when we run no ads فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Sitemap & Job run trigger فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot xf_mail_queue made system run out of disk space and crash فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can I run a forum via my iPhone? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can a long-running browser job be interrupted and run via CLI instead? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is the starter Namecheap package fast enough to run XF? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrading 2.1 to 2.2 what database queries can I run ahead of the upgrade to speed it up? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot unable to run indexing - error فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What information gets submitted to "StopForumSpam" when spam cleaner is run فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot xf:run-jobs may never stop فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot 3rd party template referenced images run through proxy.php ? فیدخوان خبری از سایت xenforo.com 0
