Does XF 2.3 require a higher MySQL maxconnections setting?
XFFA.IR Bot
امتیازها 113
راه‌حل‌ها 27
Been running XF 2.2 for. years with no issue. Just upgraded 3 sites to XF 2.3.6 and now when posting I occasionally get an Oops... error and finally learned to check the console and see the error is about MySQL max connections. I've also seen the site go down once for a MySQL error, never had that in 2.2. My max connections was set to 500 which I have now increased.
Is there a problem with XF 2.3.x either using more connections than before or not releasing them? I host my own web and MySQL...
Read more
