XF does not loop through all possible folders inside '_output' on import/upgrade
XFFA.IR Bot
امتیازها 113
راه‌حل‌ها 27
In certain situations on xf-addon:upgrade or xf-dev:import XF does not remove orphaned data from the database (data, that was removed from the _output folder).
According to my tests we need at least 1 folder inside _output (e.g. phrases). If another folder (e.g. widget_definitions) is deleted, XF does completely ignore that fact on upgrade or import and just skips removing any (in this case) widget definitions from the database.
Result: If you...
Read more
