درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Fix Direct Message Filter \"Received by\" & add \"With Participant\" ایجاد شده است. این موضوع تا کنون 1 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Fix Direct Message Filter \"Received by\" & add \"With Participant\"
I'll be honest, this one has been a thorn in my side since I started using XF way back in the early days.
This never has worked the way I expected it to. It is maddening to me. Because it has always been missing the ability to search for conversations with a specific participant. Honestly that's all I have ever really wanted to filter for.
Additionally, and more maddening, is that "Received by" does not operate logically.
These are the filtering options...
XFFA.IR Bot Best way to fix a botched add-on that causes server errors to be logged constantly? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo 2.3.9 (inc XFMG) & 2.2.18 Released (Security Fix) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Server errors after update to security fix 2.2.18 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to fix: Segmentation fault (core dumped) XF 2.3.7 , ES 2.3.5 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How To Fix Mod Queue Number When Nothing In It? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot One click feature to fix line breaks, punctuation. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How can I fix this unnecessary Google problem? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Fix detection of Opus audio files with .opus instead of .ogg extension فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Bandwidth Exceeded Error - Site Down. How to fix? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Safe to install 2.3.7 security fix on older builds like 2.3.4? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Looking for someone who can build, fix, and upgrade the Jsonld - multi adds-on فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Spammed with 'Increment on type bool has no effect' - recommended PHP version to fix? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo developer needed for fix an issue on an add-on فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to Fix Tags? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to fix thread views count if posts are cached فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Need to fix UserOption.php فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to Fix Editor Options فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [XB] Featured Content Widget Title Fix [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How can I fix the url structure? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Help Needed: Issue with Stripe Tax on XenForo 2.3 Subscriptions (Will Pay for Fix) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Why does push alert use app name plus forum name? how to fix? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Allow Security Fix for those with expired licenses فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Fix Missing Content (Thread) Types (Free addon) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Help me fix a mess with user groups (primary and additional) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot A Fix For "The File Could Not Be Written to the Server." فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image Details cut off? How to fix? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Fix theme فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [Bug Fix] Fixing Undefined Array Key Error in AbstractCollection in XenForo 2.3.0 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Fix for minor HTML error: "No space between attributes" فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot InvalidArgumentException on requests to "/login/keep-alive" after applying the 2.2.16 security fix فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Properly fix security issue with v2.2.16 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot 404 not found fix فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot New spam activity - what's the best way to fix this? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Fix handling of "tel:" URLs فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot how to fix website not showing up on google? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Scheduled Jobs Outstanding on Shared Host - How Do I Fix? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Node permission update error 403 Plesk control panel ModSecurity fix فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot RSS feed imports showing some html, like <br> tags... how to fix? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to read and fix server error logs فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to fix height for ad unit? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Vimeo BB fix? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenCircle Here for fix and Develop Addons in Reasonable Price فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do I fix embedding a gif into my forum post? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [FF] Fix WebManifest Orientation فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hello any one can help to fix this (To remove Footer ) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Google search - or just fix search function فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Errors in ACP: source and fix? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [ShikiSuen] Chinese HTML Lang Tag Fix (for XF 2.0 and 2.1 only.) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Help me figure what this 'Unknown' e-mails bounces so i can fix it. فیدخوان خبری از سایت xenforo.com 0
