درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام How should I organize this? Need input.. ایجاد شده است. این موضوع تا کنون 210 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع How should I organize this? Need input..
Okay.. So I'm working on a new project, and I need some help on the best way to organize my board game forums.
I have about 15 standard forums, which is visible on the forum index. That's ok.
Then comes the database of board games, which will consist of thousands of games eventually. Each game in my database needs to have its own forum. So naturally I would need to hide them from the node list. The same goes for group forums I'd imagine.
Also, the plan was to not split up the game...
XFFA.IR Bot Functions which use func_get_args should be typehinted with 'mixed ... $arguments' فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Blocked users should have read permissions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Threads created by a report should have any custom thread fields available to the user. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should Paid Resource Threads Be Private or Public? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should StopForumSpam Username Matches Be Ignored? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot "Complete Upgrade" link should be shown to admin/staff only فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What should I consider when buying or taking over a XenForo forum? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Forum boost should consider child nodes فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Which template should I edit for Whatsnew/New post's avatar cell? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot AbstractCollection->pluck() should always return collection when $collectionOnEmpty=true فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Clicking on partially read threads should take you to first unread page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot hasAdminPermission should check if permission exists for super admin فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I'm scared to upgrade my site to the latest XF version. Should I be? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Partial email address should not be allowed as username فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What should I do according to you? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How should new users maintain their accounts? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF\Http\Reader should not allow .internal domains to be fetched from an untrusted context فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should I Allow a User Flagged by StopForumSpam to Register? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Prefixes should change on different languages فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Elasticsearch 8.13.2 admin.php?enhanced-search/optimize as it suggested i should run it فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Do you have a sweet spot of new threads that should be created for your forum? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Pages not having "200 OK" status response code should not be reported as Last activity فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot All editors should support bbcode, when possible. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Temporary attachments should only be viewable by the session/user which adds them فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot ViewableInterface should provide a method to get required relations for canView فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What's new should say "No results" if there aren't any فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot PHP 8.2 should I upgrade? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot All should be an option when selecting forums to enable modifications/features. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot ViewableInterface class isn't used as much as it should be فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot utf8.php should be updated (php8.2) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User change logs should provide an easy revert button فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Export as independent style should be behind Development Mode فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Why should I buy this? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What conditional should I use to specifically hide a widget or a template from a certain member_view page? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Feature Content should be in inline moderation فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Are tags valuable? Under used? Should we use them in the main search? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot The <img> tag should not be displayed unless the OAuth client image URL is provided فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot My new forum got hacked, what I should do please? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Spam check on groups that should be okay فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot New testimonial for XenForo that should be added to the homepage فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Custom URL should be required field when selected فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should I change my current Hosting requirements or even a change of host? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot SEO: Should we remove the board title at the end of the "title" meta tag? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I want to make a novel forum like this. What addons should I have? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Expiring recurring user upgrade should explicitly cancel with payment provider and not assume failure فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What should I be using for Email Transport Method? فیدخوان خبری از سایت xenforo.com 0
