درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام index.html suddenly became active and replaced XenForo's index.php as the homepage ایجاد شده است. این موضوع تا کنون 5 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع index.html suddenly became active and replaced XenForo's index.php as the homepage
Hello,
I have been using XenForo on my forum for a long time. An index.html file has also been sitting on my server for a very long time.
As far as I know, this index.html file should not normally interfere with XenForo because XenForo uses index.php as its main entry point. In fact, this index.html file had been on the server for years without causing any problems.
However, yesterday, the index.html file suddenly became active and started being displayed as my website's homepage instead of...
XFFA.IR Bot Custom Page node for index not showing any content from template html فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [DD] Letter Index فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot AIXF – XFMG No Albums On Index [Deleted] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Getting rid of index.php فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Problems rebuilding search index on a large site فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Search index build with media comments is so slow it's useless. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot vbulletin redirects does not redirect /archive/index.php/t-X فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot CWP Hack Alert (not an XF exploit) that rewrites your index.php فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot SEO Utilities + Unified Index v1 [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot AIXF – XFMG No Albums On Index فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Linking back to an index فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrade to 2.3 – search index conversion to innodb فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Missing Index on addon_id columns which slows down WHERE and JOIN queries فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot index.php in other folders issue فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Batch update thread actions to index/noindex for better user experience and SEO فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Convert search index to InnoDB on shared hosting فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Duplicate Index Issue - xf_poll_response Table فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Blank index page, no errors ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XenForo in VPS - Is it a problem with Google's index? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Google Index API Integration فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Meta information not on index page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Sitemap Index Issue: فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot View index.php nodes xenForo فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Delete the search index before rebuilding? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Generated site map does not include index.php in the url فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot ErrorException: [E_NOTICE] Undefined index: report src/XF/Spam/AbstractChecker.php:39 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Index criteria: minimum words in all thread فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [cXF] Admin Search on Index فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot index.php issue فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Widget on another page than the index forum, possible? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Removal of old Addon (SEO & Index Tools) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Rebuild search index issue فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Index page route? Where has it gone? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Index Page Route Question فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot 2.3 Rebuilding index requires too much memory فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Index now error the key field is required فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Where has index page route gone? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add engine index criteria based on prefixes فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Error optimising and rebuilding search index with Enhanced Search enabled. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot how to integrate latest , top resources etc on xenforo forum index page ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Username Clipping Issue on Index فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is it normal for rebuilding search index to index missing or deleted posts? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Who uses Index threads based on criteria for SEO فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there any way for me to use google index api? فیدخوان خبری از سایت xenforo.com 0
