mbstring extension is not loaded but is required
XFFA.IR Bot
امتیازها 113
راه‌حل‌ها 27
I'm seeing the following warning in my logs:
  • ErrorException: [E_USER_WARNING] [WebPush] mbstring extension is not loaded but is required for sending push notifications with payload or for VAPID authentication. You can fix this in your php.ini. src/vendor/minishlink/web-push/src/WebPush.php:82
When I look at Server environment report on the home page of the admin panel, I do see mbstring support Yes. Is there an example of what also need to be configured to leverage the extension?
Thank you!
