درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام \"Popular\" should be first choice in nav header ایجاد شده است. این موضوع تا کنون 180 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع \"Popular\" should be first choice in nav header
When you go to a Suggestion forum, in the nav header it would look better to have Popular as the first choice, which would appear over the numbers of votes. Of course Latest would still be the highlighted one but would be second. This would follow suit in the other types like Question etc.
It just looks more logical, like you are sorting the votes and it is right above it, also then Latest, Newest (which makes sense together) appear over the title.
[COLOR=rgb(41, 105...
[URL='https://xenforo.com/community/threads/popular-should-be-first-choice-in-nav-header.187866/']Read more[/URL]
XFFA.IR Bot [XD] Popular Tags Coud فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Add the "Latest Updates—Popular—Newest" tab to other forums? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot DL6 - [Widget] Popular threads and posts فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Supporting Popular API Integrations Such as Zapier and PieSync فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Most popular threads widget? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to track most popular forum sections? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What did u do to get your forum popular? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [Jazzaaf] Popular Content فیدخوان خبری از سایت xenforo.com 0
King [Widget] Popular threads and posts افزونه های کاربردی و ظاهری 0
XFFA.IR Bot Functions which use func_get_args should be typehinted with 'mixed ... $arguments' فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Blocked users should have read permissions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Threads created by a report should have any custom thread fields available to the user. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should Paid Resource Threads Be Private or Public? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should StopForumSpam Username Matches Be Ignored? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot "Complete Upgrade" link should be shown to admin/staff only فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What should I consider when buying or taking over a XenForo forum? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Forum boost should consider child nodes فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Which template should I edit for Whatsnew/New post's avatar cell? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot AbstractCollection->pluck() should always return collection when $collectionOnEmpty=true فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Clicking on partially read threads should take you to first unread page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot hasAdminPermission should check if permission exists for super admin فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot I'm scared to upgrade my site to the latest XF version. Should I be? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Partial email address should not be allowed as username فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What should I do according to you? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How should new users maintain their accounts? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF\Http\Reader should not allow .internal domains to be fetched from an untrusted context فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Should I Allow a User Flagged by StopForumSpam to Register? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Prefixes should change on different languages فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Elasticsearch 8.13.2 admin.php?enhanced-search/optimize as it suggested i should run it فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Do you have a sweet spot of new threads that should be created for your forum? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Pages not having "200 OK" status response code should not be reported as Last activity فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot All editors should support bbcode, when possible. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Temporary attachments should only be viewable by the session/user which adds them فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot ViewableInterface should provide a method to get required relations for canView فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What's new should say "No results" if there aren't any فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot PHP 8.2 should I upgrade? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot All should be an option when selecting forums to enable modifications/features. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot ViewableInterface class isn't used as much as it should be فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot utf8.php should be updated (php8.2) فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot User change logs should provide an easy revert button فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Export as independent style should be behind Development Mode فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Why should I buy this? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot What conditional should I use to specifically hide a widget or a template from a certain member_view page? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Feature Content should be in inline moderation فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Are tags valuable? Under used? Should we use them in the main search? فیدخوان خبری از سایت xenforo.com 0
