درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Programmatically maintain route filters? ایجاد شده است. این موضوع تا کنون 40 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Programmatically maintain route filters?
The situation is the following:
We are using a platform for page building outside XenForo and basically push the page content into a node ID via API, as well as creating new nodes, setting their parents etc.
2 questions regarding that:
  1. Can route filter for pages dynamically respect hierarchy? e.g. i have a page "Team" with each Member as a subpage. This leads to pages/team, pages/adam, pages/eve etc. whch have to be mapped to /team, team/adam, team/eve etc.
    1. It was very...
XFFA.IR Bot Any way to bypass usernameValidation programmatically? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to login user programmatically in XF? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot how to maintain vb4 vbseo redirects after xf1.5 -> xf2.3.7 upgrade? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Build an addon with a resize icon to maintain the aspect ratio issue فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How should new users maintain their accounts? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How maintain current XF forum thread and post URLs and have WordPress in root directory as well? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Strange incident: Enabling a route filter caused 404 errors somewhere else – Problem with XF caching? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Route Filter CASE structure فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to properly use route filter wild cards? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Route Filters with ? or # فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Embed Komoot route via BB Code فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can you use URL Params in Route filters, and if so, how would this be done? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Route filter with Greek فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Simple "Hello World" Route فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to skip CSRF token for a specific route? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Incorrect route params in reactions list tabs link فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Route creates a double origin on the breadcrumb فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot forum/-/list url route filter? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Index page route? Where has it gone? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Index Page Route Question فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Where has index page route gone? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Inline documentation on "Route format" on add routes page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there a way to know which public route matched with a URL? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Route instead of class? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Optional route prefix فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot route filters help فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot No route to host !! فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there a way to make route filters for prefixes? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF\Mvc\Controller method buildLink does not pass parameters in route فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Route filters help فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Higher route filters level فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to set multiple route Actions in the same Controller? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot route filters فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Index page route فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Changing route filter help فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [RESOLVED]: [FQDN]/api/[any api route] returns 404 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Route filtering problem فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Just changed route filters to resource, how to 301 ? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot help with implementing new XenForo content vote system to an add-on, build link, route فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Bad uksort callback in XF\Repository\Route فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Does xf-overlay support having custom markup overlays instead of calling a route? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Consistent Forum Index H1 Title when using Index Page Route فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot router_public_setup to override buildLink/route? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Full Route Filters list فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Get no html view on route page فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Can account upgrades be route filtered? فیدخوان خبری از سایت xenforo.com 0
